2001 Chevy Blazer wont start
AL MASCOLA
  • 2001 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 170,000 MILES
2oo1 chevy blazer wont start check fuel pump have fuel to fuel rail one bad fuse taatan what ever that is? Ran some fuel down thottel body starts until runs out of gas replace crank sensor no change
Tuesday, November 3rd, 2009 AT 1:18 PM
  • 109,885 POSTS
I have no idea what taatan is. Where did you see that?
Now, if the engine starts when you manually give it fuel, you're getting spark. On the other hand, you're not getting fuel. What was the fuel pressure at the rail when you checked it. Also, have you checked for an injector pulse? You could have fuel to the rail, but if the injectors are not working, nothing will make it to the engine. Let me know what the fuel pressure is. If it is within spec, then you will need a noid light to check for an injector pulse.
Friday, January 29th, 2021 AT 11:45 AM
