Blazer started to run rough, missing. We changed all plugs and wires, new cap and rotor. EGR valve and fuel filter. Still ran like crap, assumed it was the catalytic converter stopped up the way it acted. Had new one of these put on, still will not rev up. When you take out the o2 sensor, it will run, but when you put it back in, it will not rev up. We replaced the 02 sensor, and still no luck. With the 02 sensor in, it will only go 5mph...take it out, and it will go, just not good. It still acts like it is stopped up. What else could we check or change??
Jan 5, 2010 at 4:14 AM
