2001 Chevy Blazer windshield washer
LINKONCOLT
  • 14 POSTS
Electrical problem
2001 Chevy Blazer 6 cyl Four Wheel Drive Automatic 110k miles
when you turn on windshield spray it does not work . when you turn on rear window spray it works ok. whats up with that ??
Aug 17, 2009 at 11:49 PM
2CARPRO JACK
  • 11,533 POSTS
pop the hood and see if you can hear the motor running for thefront washer.If it is running then the nozzles are probably plugged at the wipers where it comes out, this is common for car wax to plug them up.Try unhooking the rubber lines before the nozzles to see if fluid comes out.If so then they are plugged.If the motor doesnt run, use a test light to see if it is getting power when you turn it on
Aug 18, 2009 at 12:55 AM
