2001 Chevy Blazer WEIRD BRAKING PROBLEMS!
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
FROGMAN24
Sometimes, not always when I brake slighty going into turns or come to a stop and start the crank the wheel either way such as at a stop sign. I can feel the the tranny gears or flywheel teeth thru the break pedal! I'll immeadetly let of the brakes and then it's fine any ideas with this never had anything like this before. Thanks.
Feb 22, 2010 at 12:07 AM
  • 110,251 POSTS
The brakes are not connected to those parts; however, I believe you are feeling something. Does this happen as you are moving or stopped?
Feb 24, 2010 at 2:39 AM
FROGMAN24
No, it's when I'm moving. I'll be braking sometimes, less than 10 mph turning or going straight and swear the tranny is connected to the brakes. I can feel the teeth revolutions thru the brake pedal. It'll scare you! Thanks.
Feb 24, 2010 at 5:36 AM
  • 110,251 POSTS
I thing the ABS is actuating. Does it get harder to push the brake pedal? Does it feel like you loose control of the braking?
Feb 24, 2010 at 5:49 AM
FROGMAN24
No it comes to a stop just fine. It's just that damn cogging type stuff on a metal gear thing. like I said it's weird!!
Feb 24, 2010 at 7:19 AM
