2001 Chevy Blazer Weak Fuel Pressure
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
KWOZMAN
I understand i should have between 50 and 61lbs fuel pressure. Is it possible to have a weak fuel pump or does it just go out. i dont have any restrictions unless it is at the pump itself. Mine acts the same as everdee69 described in another message on a 98 blazer. My fuel pressure is about 43 or 44 at the fitting on the fuel line at the engine. Could it have just sucked up a restriction?
Mar 21, 2010 at 3:18 AM
BMRFIXIT
  • 19,053 POSTS
Low fuel pressure fuel pump need to be replaced
also check the wiring harness and connector plug of the pump
Mar 21, 2010 at 1:52 PM
