2001 Chevy Blazer Water in fuel tank
AMORADIAN
Engine Performance problem
2001 Chevy Blazer 6 cyl Four Wheel Drive Automatic
I ran out of fuel and was given a can that also had water in it. I removed tank drained replaced put good fuel in and some water remover. Is there anything else that I should do to get it started? Do the injectors need to be cleared? It stile does not start, should I just be persistent?
Mar 17, 2009 at 6:27 AM
EUGENE123
  • 273 POSTS
try changing your fuel filter
Mar 17, 2009 at 6:42 AM
AMORADIAN
Thanks for the reply very fast I may add. I have changed the filter, the system is pressurized clean gas and water remover added. Still will not start, however I have just noticed that the security light is blinking. Will this prevent it from starting? How do I disable this or reset the system?
Mar 19, 2009 at 8:56 AM
EUGENE123
  • 273 POSTS
yes this will prevent them from starting. to reset the system try disconnecting your negative terminal from your battery for 5 minutes
Mar 19, 2009 at 9:46 AM
