2001 Chevy Blazer Turn Signals
145,000 MILES • 6 CYL • 4WD • AUTOMATIC
FLYINGSOLOUSAF
I have lights all around, and I checked it. Yet when I try to use my turn signals I'm not getting them for left or right turn. Plus Nothing on the dash indicating turn signal either. Could this be a fuse problem or wire problem?
Mar 9, 2010 at 4:27 AM
LEGITIMATE007
  • 5,121 POSTS
sounds like the flasher fuse is faulty, usually located underneath the dash and attached to steering column. if not there then check in the fuse box on drivers side
Mar 9, 2010 at 5:36 AM
