2001 Chevy Blazer transmission indicator switch
181,044 MILES • 6 CYL • 4WD • AUTOMATIC
REDNECKHOSPITALITY
I read in the book that comes with the blazer,and it said if the 4x4 doesn't engage in 30 seconds that your transmisson indicator switch needs adjustment.where is the switch located at so i can adjust it to see if thats the problem.
May 27, 2010 at 8:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you are looking for the four wheel drive indicator, it is located on the front axle, right of the differential.
May 27, 2010 at 8:56 AM
