2001 Chevy Blazer Temerature Sensor
2001 CHEVROLET BLAZER
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
THEDON
My engine light is on and the code for it is PO128. It is either thermostat or temp sensor (ECT). The truck doesn't run hot or anything , so I would not believe it would ve the thermostat. Is it hard to replace the sensor and where is it located at. Thanks,
Jan 20, 2008 at 10:46 PM
DENNYP
  • 1,824 POSTS
most often, it is a bad thermostat. The sensor is located on the driver side cylinder head, near the rear spark plug. It should have a two wire connector.
Jan 21, 2008 at 2:08 PM
