2001 Chevy Blazer Radiator & overheating problem
142,000 MILES • 6 CYL • 2WD • AUTOMATIC
WILL MCDONALD
I have recently been having radiator problems!! I bought a radiator from a salvage yard and replaced my old one which had a crack in it. Once I changed the radiator and flushed it, It wasnt a week before I had a crack in the same exact spot..in the top right corner of radiator. What causes this to happen, and shoduld I keep fixing the radiator or replace something else with it?
Oct 6, 2008 at 1:59 AM
MMPRINCE4000
  • 8,548 POSTS
Flush the cooling system and block, change the thermostat, inspect the waterpump for leaks and replace if needed. Replace the rediator with a new one or get it rebuilt at a radiator shop.
It is hard to say what caused the radiator to crack again. It is used for one thing, you could have a bad thermostat, if using Dex-Cool, you may have a restriction in the cooling passages.
Oct 6, 2008 at 6:04 AM
