2001 Chevy Blazer need help
LOUCINDY
Transmission problem
2001 Chevy Blazer Four Wheel Drive Automatic
while driving blazer jerks like its trying to change gears
Nov 19, 2008 at 8:37 PM
SWILLIAMS
  • 597 POSTS
When does it act this way? Does the engine sound change when it happens? Any strange noises when it happens? Does it shift through all the gears?
Nov 20, 2008 at 3:27 PM
LOUCINDY
its doesnt make any different noise in the motor all the gears have shifted just jerks and sounds like the rear end going to lock up or something going to lock up
Nov 20, 2008 at 5:25 PM
SWILLIAMS
  • 597 POSTS
Well that could be anything. Bad chain in the transfer case, Bad U-Joint, Bad gear in a differential, Bad pinion bearing, Bad axle bearing. Transmission failing. It sounds like you need to take it to a shop and have it looked at before something really bad happens.
Nov 21, 2008 at 1:10 PM
