2001 Chevy Blazer mass air flow sensor
65,000 MILES • 4 CYL • 4WD • AUTOMATIC
BLAZER2001
The code inidicated mass air flow sensor. It was replaced. SUV continued to surge. Dealership then discovered a wire problem. It as insulated so it was not apparent as being a problem. Repaired or connected the wire. Still continued to surge. So, they were hopeful that they had discovered the problem...had something to do with the alternator sending a false message causing problem with mass air flow sensor ...something to do with the combustion level?? Sorry, it got too technical for me to understand. Anyway dealership replaced alternator. Unfortunatley, the problem was worse than ever. I think they are scratching their heads about now. Do you have any insights?
Thaniks - Charlie from Longview, WA
updated 11/5/08
Thank you so much for responding. The latest update from the Bud Clary GM dealership is that they have now installed a catalytic converter telling me that with all the surging, it has caused a problem with the converter. Friday they ordered the part. Installed it on Monday. Test drove it for about 10 miles, but wanted to keep it yet another night. They wanted to test drive it for a distance greater than 10 miles.
The check engine light has been coming on - on/off for about 2 months. Bill, at the dealership suggested that I continue driving it. It was the mass air flow sensor. But he said I could drive it. When the check engine light starts to flash, then I would need to replace it.
Well, when I had to pull off the road on in Portland, OR, 10/25, the check engine light never came on. Found a place to check out my problem Precison Auto Time. They determined the problem was the mass air flow sensor. They replaced it with a Nappa part ( I determined later that it was a refurbished part).
After this repair, we drove less than 10 miles and the problem was even worst. It was a Friday evening. Decided to have it towed back home to Longview, WA, to the dealership. Saturday morning they call me and tell me that the mass air flow sensor needed to be replaced. We suspected that the Nappa part was faulty.
Monday, 10/27, I'm off to a 100th birthday party. Twenty minutes into the my trip, the Check Engine light comes on. So, yes, in answer to your question, the light came on at this point.
The udpate on my SUV is that they have now installed a catalytic converter. Was told that with all the surging, this part now needed to be replaced. The part was ordered on Friday, 10/31. Installed on Monday. They test drove it for 10 miles, but wanted to keep my SUV yet another night because they wanted to test drive it again taking it out for more than a 10-mile test run.
Have to admit that I am a bit skeptical about what is happening. I hope they are not "grasping at straws" trying to fix my vehicle.
I will doublecheck with them to see if what the code read each time they worked on it.
Thank you~~Charlie
Oct 30, 2008 at 3:23 PM
RHALL77
  • 3,361 POSTS
does it set a check engine light. do you have the codes?
Nov 3, 2008 at 7:35 AM
RHALL77
  • 3,361 POSTS
when you get it back let me know what they say. if the check engine light comes on again, disconnect the maf sensor and drive it and see if thats better.
Nov 5, 2008 at 7:06 AM
BLAZER2001
Thanks for responding. They found that my battery had to be replaced. It was weak and they was part of the problem. Fortunately, the converter was still under warranty.
They test drove it for 24 miles before they gave my car back to me. Yesterday (Thursday) was the first opportunity I had to take it for a test drive on the highway. In ten miles, it surged 8 times. The check engine light came on. I took it right back to the dealership. Ninety minutes later, I got my car back. There was no paper work, but Bill, the customer service guy, told me that they had replaced the manifold sensor and test drove it.
Today is Friday, I will once again take it out on the highway to see how it performs. Frankly, I am a little worried that they are not going to be able to repair my vehicle. I don't think they really know what the problem is. And, I don't want to have to buy another vehicle.
Thank you. ~~Charlie
Nov 6, 2008 at 7:45 PM
