2001 Chevy Blazer loud hum or whine
78,000 MILES • 6 CYL • 4WD • AUTOMATIC
PVANZILE
The Blazer has a loud hum coming from the back end. Sounds like under the trunk area. It does it in park and in drive. Can't hear it from the engine area. Any ideas what is wrong?
Apr 11, 2009 at 10:24 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:8388e947fa="pvanzile"]Noises problem
2001 Chevy Blazer 6 cyl Four Wheel Drive Automatic 78000 miles
The Blazer has a loud hum coming from the back end. Sounds like under the trunk area. It does it in park and in drive. Can't hear it from the engine area. Any ideas what is wrong?[/quote:8388e947fa]
Since you can hear it while the vehicle is in park then check for a Exhaust Leak, it will be towards the back end. If you cannot find a leak then take a rubber mallet and tap ong the muffler if you hear rattling then you will need to replace the muffler to end the noise.
Apr 11, 2009 at 10:35 AM
