2001 Chevy Blazer head lights
2001 CHEVROLET BLAZER
79,000 MILES • 6 CYL • 4WD • AUTOMATIC
SIMMI2009
i think i have a short in my tilt steering. every time i lower it the day time running lights go out.. how easy is it to take off the steering wheel column cover and find the problem
Oct 15, 2009 at 6:01 AM
  • 110,240 POSTS
It sounds like you are correct. However, since the vehicle has an airbag, you really have to know what you are doing. If you have no experience with them, I recommend having it done by someone trained to work on them. The airbag can actually deploy if you are not careful and then you will be into a lot more money.
Oct 19, 2009 at 1:06 AM
