2001 Chevy Blazer gas performance
111,000 MILES • 6 CYL • 2WD • AUTOMATIC
EMTLBT
my question may be rather dumb but it seems that I am burning more gas latly. or a gas leak I have looked under the car to see if it is leaking but nothing and I do not smell gas either running or just after I turn it off. I am getting about 200 mi per tank. Checked the air cleaner it is clean but I was thinking if the compresser is getting ready to go would this happen?
Mar 19, 2008 at 7:07 AM
2CARPRO JACK
  • 11,533 POSTS
Has it ever been tuned up? Does it ever crank longer to start than it used to? Does it miss sometimes when you first start it? could be a fuel pressure regulator blown, letting raw fuel into the intake
Mar 19, 2008 at 7:17 AM
EMTLBT
yes it has been tuned up it starts fine doesnt act like it is missing
Mar 19, 2008 at 8:22 AM
DENNYP
  • 1,824 POSTS
A slipping transmission could cause poor fuel economy also.
Mar 19, 2008 at 1:59 PM
2CARPRO JACK
  • 11,533 POSTS
Tire pressures good? If you get tires that start with LT (light truck) they usually have a higher psi rating than a tire that starts with P (pasenger) this will help mpg a little bit due to the fact that a harder tire rolls better
Mar 20, 2008 at 12:35 AM
