2001 Chevy Blazer Gas
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
ENMONTY80
I can not put gas in my truck. Everytime I try it only allows a dollar or two then it wont take anymore like it is full. I have a quarter tank of gas and am sure of that. Its been a week since I put gas in it and I use it everyday to go to and from work. What could be causing this?
May 15, 2009 at 2:02 AM
  • 110,251 POSTS
First, there are two steel lines that in the filler tube. Try to see if something is blocking the smaller one. Also, there may be a roll over ball in the tank that is stuck. It is designed to prevent fuel from leaking from the tank in the event of a roll over. Make sure it is loose.
May 20, 2009 at 4:21 AM
