Is this a stop light switch problem?
205,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOYRAY14
Currently the exterior brake lights of my 2001 Blazer stays in while driving and the drive behind does not know when I am stopping. Is this a stop light switch problem? If so how do I replace the stop light switch?
Oct 13, 2010 at 3:52 AM
WRENCHTECH
  • 20,760 POSTS
You'd have to test it but it's most likely a bad brake light switch. It's located under the dash at the brake pedal.
https://images.2carpros.com/forum/automotive_pictures/561653_Brake_light_switch_01_Blazer_1.gif
Oct 13, 2010 at 4:13 AM
