2001 Chevy Blazer engine problem
2001 CHEVROLET BLAZER
85,000 MILES • 6 CYL • 4WD • AUTOMATIC
LCSD187
at times when I press the gas the vehicle will not go or it moves real slow and at times back fires.
Dec 31, 2009 at 4:26 PM
Your possible causes could be one of the following:
Oxygen Sensor
Catalytic Converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Coil and Rotor
Dec 31, 2009 at 6:28 PM
