Start the car, run it for over 15 minutes. get on highway for 10 mins. truck runs fine. exit highway, and at stop light engine stalls. sometimes restarts immediately other times takes two or three attempts. replaced Fuel pump 10,000 miles ago. have regular routine maintenance performed. Stall occurs intermittantly, not all the time, but is occurring more frequently. usually baby the engine by (when at stoplights, put in neutral, rev engine a bit and then return to idle before shifting into drive again).
The engine also idles at around 500 rpm.
check engine light comes on and stays on. I get a P0101 and P0442 code. No other codes present.
My friend, who has had many chevy s-10 blazers thinks that either the MAF sensor or the Idle Air control motor may be dirty or not functioning. He is an ASE certified mechanic.
What are your suggestions?
Apr 7, 2010 at 2:39 PM
