Ok, what you will need to check the Wiring Harness on that Cylinder, and in order to do that you will need a Noid Light. You can check with your local rental store or even the parts store.
If the wiring harness test good then you will need to check the Cylinder Compression.
If compression checks good you will need to check for Vacuum Leaks.
Also, has the engine been overheating? Have you had to add coolant or checked the coolant for signs of oil. Also check the oil for signs of coolant.
If either has the above then the most likely culprit is a blown head gasket.
Wednesday, March 3rd, 2010 AT 10:34 AM
