2001 Chevy Blazer COLD STARTING
EADG80
Engine problem
2001 Chevy Blazer V6 Four Wheel Drive Automatic 91,000 miles
HI . MY BLAZER SEEMS TO GO INTO IT'S OWN WORLD . IT WON'T START AND / OR DOES A LOT OF COUGHING [ ABOUT 5 MIN ] AND EVENTUALLY STARTS WITH A LOT OF TROUBLE . I HAVE A HIGH AMP / HIGH CRANK HR. 1 YR. OLD BATTERY AND A 2 MONTH OLD ALTERNATOR. THE VOLTAGE METER DROPS DOWN TO 12V OCCASIONALLY WHEN THERES A BIG LOAD ON THE ELECT. SYSTEM BUT DOES NOT STALL ANYMORE [ SINCE THE NEW BATT. AND ALT. ] IT DOES THIS ABUT ONCE EVERY 8 -12 WEEKS [ NEVER ABOVE 45 DEGREES THOUGH ] AND IT ALMOST ALLWAYS STARTS IN VERY COLD 0 -25 DEGREES . . . ANY HELP WILL BE APPRECIATED IMMENSLY - THANK YOU
Dec 9, 2007 at 7:56 PM
  • 75,988 POSTS
Start by checking the fuel pressure and then test the coolant temperature sensor and idle air control valve.
Dec 9, 2007 at 9:09 PM
