2001 Chevy Blazer Can't open back window
109,000 MILES • 6 CYL • 2WD • AUTOMATIC
JUSTIN92
The button to release my back window and the keyed button on the back does not release the window. The locking mechanism works and I can here it but it won't unlatch.
Jan 14, 2009 at 4:43 AM
DE772601
  • 123 POSTS
Hello if you can hear the lock working your going to have to crawl in the back and try to pull the plastic panel back with out breaking it and release the lock from the inside. They will sometimes stick if not used alot.
Jan 14, 2009 at 8:36 AM
JUSTIN92
I have tried to get the paneling off. I pulled and even tried to pri-it open but it won't come off. I've looked at other blazers and there are 2 screws directly behind the window and I think those are holding the paneling on. Is there a trick too getting it off without busting the panel.
Jan 14, 2009 at 9:55 AM
DE772601
  • 123 POSTS
Hell those 2 screws you see don't hold the panel in place they will be on the outside. One more thing you can try is to have someone push on the glass while you try to unlock it at the same time, this will take presure off the lock a little.
Jan 15, 2009 at 1:26 PM
