2001 Chevy Blazer cam sensor
CCBOBO35
Engine Mechanical problem
2001 Chevy Blazer 6 cyl Two Wheel Drive Automatic
where is the cam sensor located
Oct 13, 2008 at 2:29 AM
JDL
  • 16,098 POSTS
I believe it is in the distributor, three wire connector.
Oct 13, 2008 at 4:14 AM
SWILLIAMS
  • 597 POSTS
Jdl is correct. The cam sensor is inside the distributor body. Pull the cap and rotor and you can remove the sensor. BUT follow the proper method to install it or you will set a code unless you're VERY lucky.
Oct 13, 2008 at 10:04 AM
