2001 Chevy Blazer Brake Lights
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
MMINTY
The brake lights do not work. The brake light above the rear hatch does work. The turn signals on both sides work. What might the problem be?
The fuse box under the hood has the fuse for the brake lights. That fuse is good.
Both filiments work. One for the turn signals/ brakes. The other filiment is for the tail lights. There are two bulbs in the tail light hosing both filiments work in each bulb.
Thanks for your ideas.
Any thing else I can check?
Apr 29, 2008 at 8:29 AM
RHALL77
  • 3,361 POSTS
check and see if there is a fuse for the brake lights. could be a possible brake switch. let me know what you find i can see what we can do to help you
Apr 29, 2008 at 8:44 AM
BUZZSAW
  • 1,198 POSTS
[quote:e943188659="rhall77"]check and see if there is a fuse for the brake lights. could be a possible brake switch. let me know what you find i can see what we can do to help you[/quote:e943188659]
if the 3rd brake light works, its your bulbs, the turns work but brake doesnt, there double filimant bulbs, 1 for brake and 1 for turn signals
Apr 29, 2008 at 9:38 AM
RAYQIX
What about the Grounds or the Sockets?
I'd also think it's possibly a grounding issue.
May 2, 2008 at 3:45 AM
BUZZSAW
  • 1,198 POSTS
[quote:a6344f6367="RayQix"]What about the Grounds or the Sockets?
I'd also think it's possibly a grounding issue.[/quote:a6344f6367]
if it was a ground issue your 3rd brake light wouldnt work either same circuit
you can check your sockets with a test light
May 2, 2008 at 5:09 AM
