2001 Chevy Blazer Brake light problem
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
NOTTA CHEVY GUY
I am having a problem with my wifes Blazer. 2001 and nothing but problems. The newest problem is the brake lights. the upper led light works but the two side lights are not working. It happened before and i checked the bulbs on the driver side and wiggeled the wires under the bumper and then they worked. I found a trailer harness stuffed on top of the spare wheel that was severly corroded. After cutting off the connector I taped it up and wire tied it up. I dont have the slightest clue where to start. any info would be great. Thanks for any help.
Nov 25, 2009 at 2:02 PM
  • 75,988 POSTS
Wiggling it and it comes on tell you there's a wiring problem could be shorted or open and not visible
Nov 25, 2009 at 6:52 PM
JAYDANRILEY
I have a 2000 chev blazer that has been alot of problems as well and when I had no brake lights, I had to replace the whole blinker switch on the steering column, the stick that has ur cruise, wipers and blinkers on ithope this helps, if you have had any problems with your rpm gage jumping all over and the truck hesitating when you accelerate, please reply back to me with the info, thanks!
Nov 27, 2009 at 3:29 PM
