2001 Chevy Blazer air pump
79,000 MILES • 6 CYL • 4WD • AUTOMATIC
HDGILBERT
info on replacing an air pump?
Feb 16, 2009 at 3:04 AM
RHALL77
  • 3,361 POSTS
it is located in the lower fornt of the vehicle. remove the splash cover and you will see it. make sure you also replace the vavle down there also and reroute the intake hose so it doesnt fill up with water again. if your not sure have a professional do it
Feb 16, 2009 at 11:31 PM
