2001 Chevy Blazer acceleration
2001 CHEVROLET BLAZER
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
LINKONCOLT
  • 14 POSTS
my wifes blazer has no acceleratio at all. i mean with the pedal to the floor it acts like it is towing a semi truck. any suggestions ?
Jun 13, 2009 at 11:23 PM
2CARPRO JACK
  • 11,533 POSTS
Loosen the exhaust before the cat converter to see if you have restrictive exhaust.It will be loud, but it will run ok if the cats are the problem
Jun 14, 2009 at 1:49 AM
LINKONCOLT
  • 14 POSTS
are you saying that a restricted cat could be the problem ?? unhooking it is the only way to determine if it is a restricted cat ?
Jun 14, 2009 at 11:17 PM
2CARPRO JACK
  • 11,533 POSTS
It isn the only way, a backpressure gauge can be installed to see if it has too much, loosening the pipes is a quick way of seeing if it is the problem, and it is something you can do yourself
Jun 15, 2009 at 1:02 AM
