2001 Chevy Blazer
LAZER262001
Engine Mechanical problem
2001 Chevy Blazer 6 cyl Two Wheel Drive Automatic
what is the timing supposed to be set at
Oct 1, 2008 at 10:29 PM
SWILLIAMS
  • 597 POSTS
Timing is set by the PCM. Nothing to adjust. If you pulled the distributer you will need to set the cam offset. That can be difficult without a proper scan tool.
Oct 2, 2008 at 3:58 PM
