2001 Blazer running rough
RIDDLEBOX53204
  • 5 POSTS
I just bought a 2001 Blazer and it started acting up the day after. I was at a stop and when I pressed the gas pedal nothing was happening, then it was revving up and down until the service engine light came on. I checked the guages and all seemed normal so I looked under the hood for any visual problems, still nothing. I started it and it ran fine the rest of the way home. My friend did a diagnostic test and it came up with 0300 random misfire, and 0150 O2 sensor. It was running fine again and then last night it ran like garbage again, where I would step on the gas and nothing would happen. I felt a clicking when I had my foot on the pedal and it would stop after it registered that it was getting gas , but it eventually died in the middle of an intersection. I drove it home and didn't drive it until today where it ran fine again. I was thinking that it was the fuel pump, but before spending the money for that I wanted to get other opinions.
Aug 19, 2007 at 7:01 PM
  • 75,988 POSTS
[quote:3c9a8631f5="riddlebox53204"]I just bought a 2001 Blazer and it started acting up the day after. I was at a stop and when I pressed the gas pedal nothing was happening, then it was revving up and down until the service engine light came on. I checked the guages and all seemed normal so I looked under the hood for any visual problems, still nothing. I started it and it ran fine the rest of the way home. My friend did a diagnostic test and it came up with 0300 random misfire, and 0150 O2 sensor. It was running fine again and then last night it ran like garbage again, where I would step on the gas and nothing would happen. I felt a clicking when I had my foot on the pedal and it would stop after it registered that it was getting gas , but it eventually died in the middle of an intersection. I drove it home and didn't drive it until today where it ran fine again. I was thinking that it was the fuel pump, but before spending the money for that I wanted to get other opinions.[/quote:3c9a8631f5]
If it was me I'll check the fuel pressure for a start to find out what's happening with the pumper.
Aug 19, 2007 at 8:40 PM
  • 75,988 POSTS
[quote="rasmataz"][quote:84ed670552="riddlebox53204"]I just bought a 2001 Blazer and it started acting up the day after. I was at a stop and when I pressed the gas pedal nothing was happening, then it was revving up and down until the service engine light came on. I checked the guages and all seemed normal so I looked under the hood for any visual problems, still nothing. I started it and it ran fine the rest of the way home. My friend did a diagnostic test and it came up with 0300 random misfire, and 0150 O2 sensor. It was running fine again and then last night it ran like garbage again, where I would step on the gas and nothing would happen. I felt a clicking when I had my foot on the pedal and it would stop after it registered that it was getting gas , but it eventually died in the middle of an intersection. I drove it home and didn't drive it until today where it ran fine again. I was thinking that it was the fuel pump, but before spending the money for that I wanted to get other opinions.[/quote:84ed670552]
Random Misfire normally is an indication of vacuum lead and bad gasolina.
EGR!!!!!!!
Aug 19, 2007 at 8:44 PM
RIDDLEBOX53204
  • 5 POSTS
EGR!!!!!!!
Would this explain the clicking under the gas pedal?
Aug 19, 2007 at 11:14 PM
