2001 Blazer Automatic started jerking
ROCKYCHEVY
2001 Chevy Blazer; 57,000 miles; Automatic; 4X4
While driving on the highway several days ago, my blazer started "jerking" ever so often when I reached higher speeds, around 65 mph. Been doing it ever since. Will drive ok for a while, then the jerks start. Tend to notice more in the afternoon. Thanks for any help.
Sep 28, 2007 at 1:18 PM
DENNYP
  • 1,824 POSTS
[quote:a2ee616811="rockychevy"]2001 Chevy Blazer; 57,000 miles; Automatic; 4X4
While driving on the highway several days ago, my blazer started "jerking" ever so often when I reached higher speeds, around 65 mph. Been doing it ever since. Will drive ok for a while, then the jerks start. Tend to notice more in the afternoon. Thanks for any help.[/quote:a2ee616811]check the inside of the distributor cap for corrosion.also check for poor connections at the cap where the plug wires go into it.If this doesnt show anything, you can remove the crank sensor located in the lower part of the timing chain cover and check the sensor for any marks where it might be contacting the reluctor ring.
Sep 28, 2007 at 2:42 PM
