2000 Chevy Blazer wont come out of 4wheel dtive
2000 CHEVROLET BLAZER
116,000 MILES • 6 CYL • 4WD • AUTOMATIC
BEAZELL
will not come out of auto 4 wheel
Aug 26, 2010 at 3:59 AM
MADMIKE1735
  • 951 POSTS
those are electronically controlled... usually if they stay engaged its the module located under the passenger side kick plate under the dash... however you may be looking at a transfer case issue so best bet is bring it to a garage... you can rule out the push button select switch, thats definatly not the cause....
Aug 26, 2010 at 2:21 PM
