2000 Chevy Blazer Will not start
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
SDBROWN
I have replaced the fuel filter and spark plugs. After the repair my car was still hard to start. It would cut out or not excellerate when pressing on the gas. Now it will not start at all.
Any answers?
May 2, 2008 at 7:19 AM
MERLIN2021
  • 17,250 POSTS
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
http://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
http://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one!
May 2, 2008 at 7:25 AM
