what kind of oil
CRISFLIP
Six cylinder two wheel drive automatic 92,000 miles
can you please tell me what kind of oil i should use for my vehicle? It is a v6 4.3 automatic.
Mar 17, 2008 at 12:03 PM
THE FACTORY MAN
  • 50 POSTS
What does your owners manual say? It is best that you do not second guess the people that engineered your car. My guess is it is probably 5W-30 but look at the manual. I would use a synthetic oil such as Mobil 1 if it was my vehicle. My experience with it in vehicles with high and low miles has been great.
Mar 18, 2008 at 2:53 AM
MIKE H R
  • 3,094 POSTS
most vehicles have different thicknesses depending where you live if the climate is very cold then 5w 20 would do for the winter, if in warm climate 20w 30 is better. if the engine has seen a lot of miles them 20 w 40 would be best. but the normal oil is 20 w 30.
Mar 18, 2008 at 3:01 AM
DENNYP
  • 1,824 POSTS
It requires 5w30, but you may substitute with 10w30. Factory man was right on with the Mobil1 suggestion. GM requires Mobil1 synthetic oil in their high performance engines due to its unbeatable performance.
Mar 19, 2008 at 2:06 PM
MIKE H R
  • 3,094 POSTS
I guess it comes down to what you want to spend for oil, at most of the oil changes around here they use vavoline 10w 30 sythetic oils are good just how much you want to spend.
Mar 24, 2008 at 3:30 AM
