2000 Chevy Blazer torque specs
2000 CHEVROLET BLAZER
JTB2141982
Transmission problem
2000 Chevy Blazer 6 cyl Four Wheel Drive Manual
i was wondering what the torque specs for the flywheel bolts and clutch bolts are....how many foot lbs should they be torqued to?
Mar 10, 2009 at 9:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Using the clutch alignment tool to support the clutch, align and install the clutch plate and cover assembly. If a new clutch is being installed align the manufacturer's marks as directed.
Install the washers and bolts, then tighten each bolt one turn at a time to avoid warping the clutch cover. If spring washers were used, new ones should be installed. Once the bolts are fully threaded, tighten each one to 29 ft. lbs. (40 Nm).
Clutch plate/clutch cover assembly to the flywheel. Tighten the bolts to 33 ft. lbs. (45 Nm) for 2.2L engines or to 29 ft. lbs. (40 Nm) for 4.3L engines.
Thanks for using 2CarPros.com!
Mar 10, 2009 at 11:18 AM
