2000 Chevy Blazer tires are roaring
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
HOGTOWNREB
  • 6 POSTS
last week we drove over ice hard ,in the street. after that happened i heard the tires making a roaring sound..begins about 25 mph and get louder as i pick up speed. what parts in the frontend could have broke? i jacked up both sides, i shook the wheel from top 12 0clock and 6 0clock postion no movement on driver side and pass side.then i shook 9 oclock and 3 oclock postion and it has movement on both tires this way. what parts could cause this problem ? thanks
Jan 26, 2010 at 12:13 PM
OBXAUTOMEDIC
  • 3,713 POSTS
Did you put it in 4 wheel drive? If so could be that it hasn't completely disengaged. Also have you checked the front end fluid.
Also check the tire for uneven ware.
Jan 26, 2010 at 12:23 PM
