2000 Chevy Blazer stalling
74,000 MILES • 6 CYL • 4WD • AUTOMATIC
KIKINORCASS
Hello, I have a 2000 chevy blazer and when I am sitting at a stop light and start moving slowly my rpms drop and my oil pressure gauge wobbles I am getting an error code of p1187 on the engine codes list. If i start fast it doesnt do it any ideas what can be wrong?
Feb 28, 2008 at 3:06 PM
PEAR69
  • 1,482 POSTS
Well, a p1187 code can mean two different things. Is your engine diesel or gas powered?
This code in a diesel is a low voltage reading on the EOT (Engine Oil Temp.) sensor.
This code in a gas engine is a shorting or a low voltage signal in the bank two oxygen sensor. In this case check for any burnt or worn out wires for that o2 sensor.
BTW--make sure it is a P1187 and not a p1189..
Feb 28, 2008 at 7:24 PM
