squeaking noise from front drivers side stops when you step on brake pedal replaced pads cleaned and lube caliper still get squeak
Mar 20, 2008 at 11:49 AM
SERVICE WRITER
✓Experienced Mechanic
For what it matters...These are the spots I like to cover with lube:
If you used a proper grease on these areas, then I would nect look at glasing on the pads and rotors. Some are more susceptible to a glazed surface. Which can be sanded off sometimes.
Mar 20, 2008 at 11:51 AM
D1M1M24
MEMBER
thanks i lubed parts rotors were said to be cut before i bought truck i will give it a try thanks agian
Mar 20, 2008 at 12:03 PM
SERVICE WRITER
Make sure you measure them....Actually get replacements if your pulling them apart. They are reasonable in cost and will warp...you just don't get machinings like you once did. Once htey are cut they can't handle the heat and end up warping.
I am VERY partial to this kind of lube myself.
Mar 20, 2008 at 12:06 PM
D1M1M24
MEMBER
thanks again i will get new rotors let you know how it turns out
