2000 Chevy Blazer shift timing solenoid
DOGGIE13
Transmission problem
2000 Chevy Blazer 6 cyl Two Wheel Drive Automatic
replaced the two solenoids behind trans pan because code p0785 now the same code comes back and a new one p0785pd what does this mean what can i do
Oct 26, 2008 at 8:08 AM
SWILLIAMS
  • 597 POSTS
Check the wiring harness to the solenoids for damage and make sure they are installed properly.
The pd simply means it is a pending code. I would probably erase the codes, then check the wiring and the trans itself. Keep in mind that the fault could be in a sensor that monitors the solenoid functions.
Oct 27, 2008 at 6:45 AM
