2000 Chevy Blazer Service 4 wheel drive warning light.
2000 CHEVROLET BLAZER
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
HORSEFARMER
Will not shift into 4 low. I push the botton it flashes and you hear it try to shift at the transfer case then it clunks again and goes back to 2 wh high. Service 4 wheel drive light comes on randomly. When service 4wh light is on it will not shift to any 4wh dr. and the indicator light does not show what drive mode it is in. I think it may be wiring connectors or bad ground as I had the transfer case out resently when I overhauled the transmission.
Jan 11, 2008 at 1:30 PM
BMRFIXIT
  • 19,053 POSTS
[quote:10881d6e26="Horsefarmer"]Other Category problem
2000 Chevy Blazer 6 cyl Four Wheel Drive Automatic 120000 miles
Will not shift into 4 low. I push the botton it flashes and you hear it try to shift at the transfer case then it clunks again and goes back to 2 wh high. Service 4 wheel drive light comes on randomly. When service 4wh light is on it will not shift to any 4wh dr. and the indicator light does not show what drive mode it is in. I think it may be wiring connectors or bad ground as I had the transfer case out resently when I overhauled the transmission.[/quote:10881d6e26]
change the 4x4 switch on the dash board
very common
Jan 11, 2008 at 1:46 PM
