2000 Chevy Blazer rear washer
LINKONCOLT
  • 14 POSTS
Interior problem
2000 Chevy Blazer 6 cyl Four Wheel Drive Automatic
washer fluiddrips from headliner above rear window.how isl long plastic piece removed above rear window ?1.00
Dec 27, 2008 at 1:46 AM
SWILLIAMS
  • 597 POSTS
There are spring clips that hold it in place. Slip a trim tool or a putty knife between it and the headliner and gently pull straight down to disengage the clips. You will probably find a bad connector where the vinyl line connects to the rubber line.
Dec 27, 2008 at 11:36 AM
