2000 Chevy Blazer Oil Leak
150,448 MILES • 6 CYL • 4WD • AUTOMATIC
LUCA1BLAZER
What would cause the oil to leak out overnight? It was sitting for several hours, I moved it and then it sat all night. When I went to start it at 5AM it didn't start right away. When it did, I noticed the oil pressure gauge was pegged left as driving away. I pulled over and checked the dip stick and no oil:(. Then I returned home looked in the driveway and I saw the oil where the vehicle had been parked.
Dec 3, 2009 at 11:31 PM
DOCFIXIT
  • 18,828 POSTS
Did you refill and check for leak?
Dec 4, 2009 at 2:53 AM
SWILLIAMS
  • 597 POSTS
Where to start, Bad oil cooler line, bad remote filter line, bad oil filter, drain plug fell out, more than one seal on the oil filter, cracked oil pan.
Only way to find it is to look.
Dec 4, 2009 at 1:36 PM
