2000 Chevy Blazer Hard to start when engine is warm
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
RHORHOSIG
I have a 2000 Chevy Blazer-Trailblazer with the 4.3 V6. On cold days, or when the vehicle sits for extended periods of time, the vehicle starts quickly and effortlessly. If the engine is at operating temperature and warm, it often cranks over for quite some time before the vehicle starts. When the vehicle is going through this long cranking process, I can either step on the gas pedal to help start the vehicle or I can just keep cranking the engine. Either way, the vehicle will start and will always start no matter what. However, the issue bothers me to no end, as I cannot find the problem. Most of the answers on the internet suggest I check the fuel pressure, but to me, that doesn't explain why the vehicle only starts normally when cold, and not hot. I believe some how the temperature of the engine is causing some sort of valve/gauge/system to not properly operate while starting. Somewhere in the starting process, the engines temperature is causing an issue.
Mar 12, 2010 at 9:09 PM
SERVICE WRITER
  • 9,123 POSTS
Because there were fuel issues with this truck, fuel pressure is recommended to be verified it is in spec. The fuel injection systems on these were problem matic. The fuel may be vaporizing due to a leaking unit when the engine is hot. So it should be checked.
Having said that, spark needs to be verified for presence as well. This can be done with a spark tester and checked WHEN THE PROBLEM IS PRESENT. A loss of spark can be from a sensor or a module. Certainly want to get thais nailed down or you'll kill the starter motor.
Mar 12, 2010 at 10:03 PM
