2000 Chevy Blazer gas gage bouncing around
REDWINGER102004
  • 2000 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 191,000 MILES
My gas guage is bouncing around is this a sign of needing a new fuel pump?
Thursday, October 29th, 2009 AT 11:28 AM
  • 109,885 POSTS
Actually, the fuel pump is most likely fine. However, the float assembly may be the problem, and it is part of the fuel pump.
Thursday, October 29th, 2009 AT 11:30 AM
REDWINGER102004
Thanks for the advice I appreciate your help. Well seems like no matter what if I want the gas guage fixed its the fuel pump hmmmmmm another 2 hundred dollars.
Thursday, October 29th, 2009 AT 2:36 PM
  • 109,885 POSTS
Keep in mind, the float sends a signal to the body control module and then to the gauge. You may want to have them checked. I would hate to see you replace the fuel pump and it not take care of the problem.
Friday, October 30th, 2009 AT 7:13 AM
