2000 Chevy Blazer fuel gauge
GBOHANAN
  • 2000 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 133,000 MILES
My fuel gauge bounces around when the gas tank gets little low and then it jumps back to full low fuel little comes on and it will go to half tank then back to full. How do I fix this problem without spending to much money?And what is the problem?
thank you
Saturday, March 1st, 2008 AT 4:38 PM
MASTERTECHTIM
  • 4,750 POSTS
If it usually does it at the same level of fuel then your problem is the fuel level sender in the gas tank. You will need to remove gas tank and install a new sender assembly.
Saturday, March 1st, 2008 AT 4:40 PM
