2000 Chevy Blazer fuel gauge
133,000 MILES • 6 CYL • 4WD • AUTOMATIC
GBOHANAN
my fuel gauge bounces around when the gas tank gets little low and then it jumps back to full low fuel little comes on and it will go to half tank then back to full. how do i fix this problem without spending to much money?and what is the problem?
thank you
Mar 1, 2008 at 8:38 AM
MASTERTECHTIM
  • 4,750 POSTS
if it usually does it at the same level of fuel then your problem is the fuel level sender in the gas tank. you will need to remove gas tank and install a new sender assembly.
Mar 1, 2008 at 8:40 AM
