fuel filter location?
124,000 MILES • 6 CYL • 4WD • AUTOMATIC
where is the fuel filter located?
Mar 27, 2008 at 12:33 PM
BMRFIXIT
  • 19,053 POSTS
the fel filter is under the truck in the rail follow the fuel lines. Here is a guide to help walk you through the steps and the location in the diagrams below.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Mar 27, 2008 at 12:55 PM
JSANDRI5
Where is the fuel filter located for my blazer.
Mar 7, 2019 at 4:32 AM (Merged)
SWILLIAMS
  • 597 POSTS
Mounted on the inside of the frame rail just below the drivers door. Uses a quick disconnect on one end and a threaded fitting on the other. Make sure you relieve the fuel pressure before you try to remove it. Also have a catch basin handy since you will lose some gas anyway.
TULONGHORNS08
I do not know where to look for a fuel filter.
JDL
  • 16,098 POSTS
Look under the vehicle, inside frame-rail. If you have a new fuel filter, then you know what it looks like. Just be sure there is no pressure on the system, before you take anything loose.
Mar 7, 2019 at 4:33 AM (Merged)
CBM64699
S10 chevy blazer 92- where is the fuel filter located?
RHALL77
  • 3,361 POSTS
they are usually located on the drivers side frame rail towards the middle of the vehicle.
WOOWOOLMC
I have a 1988 Chevy Blazer 2.8 v-6 four wheel drive automatic and we have changed the spark plugs, cap, coil and put in fuel injection cleaner and dry gas.
It idles low and stahls out all the time and when we put in in gear it stalls right out. When trying to drive it has no power at all and keeps stalling out.
The fuel pump was replaced last year and we are thinking that they did not change the fuel filter at that time.
Where is it located on this model? Thanks for all your help.
SWILLIAMS
  • 597 POSTS
Filter is inline toward the front of the engine hidden by the lower radiator hose.
However I would check the compression as well.
GOING CRAZY22
Engine Mechanical problem
1991 Chevy Blazer 6 cyl Four Wheel Drive Automatic
where is fuel filter
  • 75,988 POSTS
The fuel filter is on the left frame rail just under the drivers seat.
MIAHCOMBS
1994 chevy blazer s10 tahoe package, V6 Vortech, 127,000 miles, automatic, 4x4.
I can't find my flue filter and need a little help.
BOOTDOG
  • 665 POSTS
look down the frame rail on the drivers side. follow the fuel lines back to the tank and you'll see it.
DADDYACK
Where can I find The fuel filter on my 95 Blazer?Also
is the fuel pump in the tank?
DOCFIXIT
  • 18,828 POSTS
Yes pump is in tank. Filter is in fuel line follow the lines should be three and you will find along the frame.
Hope this helps
JOHN HENRICKS
Engine Performance problem
1987 Chevy Blazer V8 Four Wheel Drive Automatic
where are the fuel filters?
JMALECKI
  • 118 POSTS
Hello
One is inline under the truck this is the on that gets changed with maintainance. The other is in the fuel tank this one gets changed when the fuel pump is changed.
John
THOMIS
I have never done this. Please help me identify any special tools necessary for changing the fuel filter in my 98 Blazer. I am not sure where it is either. Thank you for your help. Kind regards,
Thomis
BMRFIXIT
  • 19,053 POSTS
its under truck just follow the fuel line
you may need 5/8 and 3/4--------16 and 19 or 21
line wrench
THOMIS
thanks very much
HUDSONT
1996 Chevy Blazer 4 cyl Four Wheel Drive Automatic
i have a 1996 chevy blazer 4.37 and i cant find the fuel filter to change it where is it
ROB2008
  • 258 POSTS
1.Under vehicle, driver side, below seating area, driver side of transmission, mounted on frame rail in fuel line.
Good luck ,
-Rob
TNIEMOTH
  • 75,988 POSTS
Fuel Filter Fuel Filter At Left Side Frame Rail
https://images.2carpros.com/forum/automotive_pictures/12900_fuelfilterblazer_1.jpg
RICHARDALT1
1992 Chevy Blazer 6 cyl Four Wheel Drive Automatic
The engine starts but won't stay running. I suspect the fuel filter may be clogged. I have located the fuel filter on the drivers side underneath the vehicle.
In order to change the filter do I need to drain the gas tank? I am afraid the fuel will pour out once I disconnect the fuel line from the filter?
WRENCHTECH
  • 20,760 POSTS
You will have some fuel leakage but have a pan and the new filter ready and you won't lose much.
I wouldn't get my hopes too high on that resolving your problem though. That is a high flow, pass through filter and generally doesn't prevent a car from starting but a restricted filter will lead to a fuel pump failure.
MGMILLER
how do you replace the fuel filter on a 2000 chevy blazer v6
JDL
  • 16,098 POSTS
The filter has a threaded fitting on one end, use a couple of wrenches, and quick connect fitting on the other end. The autostore sells a tool for the quick connect fitting. Make sure there is no fuel pressure on the system before taking anything loose.
  • 75,988 POSTS
REMOVAL PROCEDURE
TOOL REQUIRED
J 34730-1A Fuel Pressure Gauge
IMPORTANT: Inspect the fuel tank internally and clean the fuel tank if you find a restricted fuel filter. Refer to Fuel System Cleaning .
CAUTION: Refer to Battery Disconnect Caution in Service Precautions.
Disconnect the negative battery cable.
Relieve the fuel system pressure. Refer to Fuel Pressure Relief Procedure .
Clean all the fuel filter connections and the surrounding areas before disconnecting the fuel pipes in order to avoid possible contamination of the fuel system.
Disconnect the quick connect fitting (3) from the fuel filter outlet.
Disconnect the threaded fitting from the fuel filter inlet.
Remove the fuel filter bracket bolt.
Disconnect the fuel pipes from the fuel filter bracket.
Remove the fuel filter from the bracket.
Inspect the fuel O-ring for cuts, nicks, swelling or distortion. Replace the O-ring if necessary.
