2000 Chevy Blazer fuel delivery problem
131,200 MILES • 6 CYL • 2WD • AUTOMATIC
ART21
car was running fine. went into store. when came back out the engine would not start. can put fuel in throttle body and it starts but quits after a few seconds.
Jan 1, 2010 at 2:55 PM
  • 75,988 POSTS
When you turn key to On-do you hear the fuel pump come On. If so check the fuel pressure if its within specs and also for injection pulses from the injectors if both okay check and test the fuel pump fuse and fuel pump relay-
Apr 9, 2018 at 7:28 AM
