2000 Chevy Blazer front hubs
2000 CHEVROLET BLAZER
10,900 MILES • 6 CYL • 4WD • AUTOMATIC
JD IRRERA
called dearler to get blaxer front end aligned delaer stated that i needed to get the hubs replaced had them both done a couple of years ago dealer said that both had to be replaced because they only last for 30,000 miles is this true
Jun 23, 2008 at 8:26 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:508b93d902="jd irrera"]Suspension problem
2000 Chevy Blazer 6 cyl Four Wheel Drive Automatic 109,00 miles
called dearler to get blaxer front end aligned delaer stated that i needed to get the hubs replaced had them both done a couple of years ago dealer said that both had to be replaced because they only last for 30,000 miles is this true[/quote:508b93d902]
Whether you are talking about the hub bearings or the 4 wheel drive hubs. I would take it to wheel alignment place and see what they say. I don't agree with what they say. I have known hubs to last many, many years as long as the maintenance is kept up.
Jun 26, 2008 at 5:19 PM
