Front End Squeaking - Front brakes?
82,000 MILES • 6 CYL • 4WD • AUTOMATIC
TCOLT88
When I'm going down the road the front end makes this squeaking noise noise. I can't figure out what it is or where it is coming from. I think I need new brakes can you help?
Jul 26, 2009 at 2:18 AM
SQM
  • 6,383 POSTS
Does the squeaking noise change when you apply the brake?
Typically if there is an issue with the pads, rotors or calipers; the noise will either increase decrease or go away when you apply the brake.
If the brake sequels when you drive down the road, you could have a sticking caliper. In which the brake pads stays contacted with the rotor all the time and make noise. It is a result of defective caliper or a collapsed brake hose to the caliper, which is not allowing the caliper to retract back.
When you have a sticking caliper it usually damages the pads and rotors. So it is recommended to change all of those components out.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
https://www.2carpros.com/articles/brake-caliper-replacement
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
https://youtu.be/9pwFodKAl5A
I have attached the brake inspection as well as complete replacement procedures for pads, rotors and calipers for your reference.
Jul 22, 2021 at 3:26 AM
