2000 Chevy Blazer Engine Tapping
2000 CHEVROLET BLAZER
85,000 MILES • 4 CYL • 4WD • AUTOMATIC
TWATKEYS
Thank you so much for attempting to help me because we are stumped! When you start my car the enging makes a tapping noise, it sounds like the oil isn't getting to the motor. Once the oil heats up the noise clears up. We tried changing the oil pump, put Lucas Oil Treatment in it, tried a more expensive oil filter, Changed the weight of the oil and nothing seems to be working. After changing the oil it would clear up for about 3 weeks, and also when it would make the noise and even after iwhen you go on the gas the oil pressure would shoot clear up to 80-the farthest it will go, then after you go a little while it would go back down between 40 and 60. Please help!
Tara
Aug 27, 2008 at 10:46 AM
  • 31,937 POSTS
Hi there,
If this noise is at the top of the engine, you may well have a faulty hydraulic valve lifter, ask a mechanic to have a listen as it is a very easy noise to diagnose when heard.
Mark (mhpautos)
Aug 27, 2008 at 10:43 PM
